TP-LINK Archer VR900 AC modem /router...any comments?
- TP-LINK Archer VR900 AC modem /router...any commen...
14-12-2015 8:59 AM
Many thanks in advance,
Nick
Re: TP-LINK Archer VR900 AC modem /router...any comments?
14-12-2015 11:19 AM
http://www.kitz.co.uk/routers/tplink_Archer_VR900_review.htm
14-12-2015 11:37 AM
Quote Have you seen this review?
I have now, very many thanks for the heads up! That is an incredibly useful review.
It looks ideal to me, particuarly the stability & excellent wifi. The rest of the stuff about line stats & interfaces is lost on me & therefore of no significance. I'm pretty sure that I'll go ahead & buy one.
14-12-2015 12:04 PM
14-12-2015 1:21 PM
Quote have you read post 2 in this thread
That is totally at variance with Kitz's review so I'll disregard it. Thanks for taking the time to send the info.
14-12-2015 1:25 PM
kitz is just a standard review of the hardware.
you'd be foolish the disregard anything without further investigation.
you have 1 review saying it's OK, and 1 review saying there has been problems.
that's not enough to base any judgement either way.
14-12-2015 1:39 PM
Quote kitz is just a standard review of the hardware.
Kitz's review was based on 2 weeks solid connection. I have also read other excellent reviews on several other forums. Every router causes problems for someone, often due to operator error. Thanks anyway for your concern Chenks, I'll report back once I have it up & running.
14-12-2015 1:43 PM
TP-Link is a fairly low cost brand, the stuff ought to work basically OK, but you probably shouldn't expect too much of it.
14-12-2015 1:45 PM
York.
14-12-2015 1:48 PM
that's always a good basis to start from.
lots of reported sync and stability issues.
14-12-2015 1:50 PM
York.
14-12-2015 1:57 PM
specifically asking for comments from plusnet users who had used one - i linked to one and the OP chose to disregard it instantly.
14-12-2015 2:08 PM
York.
15-12-2015 2:50 PM
15-12-2015 9:08 PM
but I rather doubt that will happen /
