TG585v7 firmware
Marked
TG585v7 firmware
The firmware preinstalled with the plusnet router does not have the option of parental, althogh manuals state this capability. The hardware is capable of this, its just the plusnet interface that ommits this.
I cured this by downloading  a USA patch and it worked.
Couple of questions:
Is it OK to use USA wireless in this country?
Also, does anyone know of a generic patch that is specific to europe, and can be configured for plusnet.  I require an instllation wizard, not just the binary update.
1 REPLY
newthing
Re: TG585v7 firmware
Should be OK in UK
the US use  wireless G channels 1 to 11
we use 1-13
so u may lose a couple of options if you are in a congested wireless area,
but not illegal
.Toby
