TG582N - DNS Client, what is it?
- TG582N - DNS Client, what is it?
16-10-2015 9:46 PM
What is the "DNS client" on the Technicolor TG582N router?, setting the state to disabled produces no difference. Everything works as is. If this is the case then what is it and why is it needed?. I've tried looking around on the internet but i cant find any answers.
In the TG582N telnet manual, it says this is the "DNS resolver configuration" yet it is called a "DNS Client".
7 REPLIES 7
Re: TG582N - DNS Client, what is it?
16-10-2015 9:57 PM
I think it's what the router itself uses to lookup hostnames. For example, when the router synchronises its clock, it needs to lookup the IP addresses for ntp.plus.net. I'm not sure exactly what happens if you disable it.
16-10-2015 10:07 PM
Also what good is "127.0.0.1" as the DNS for the DNS client?
16-10-2015 10:17 PM
That's the loopback address for the router itself, so it will use the DNS server running on the router, the same as what computers connected to the router will use (by default).
17-10-2015 1:11 AM
Quote from: anon9208123 What is the "DNS client" on the Technicolor TG582N router?, setting the state to disabled produces no difference. Everything works as is.
So it seems... until you visit a site you've never visited before and get the page cannot be found message.
Thats why windows keeps a DNS cache - a backup of the previous dns lookups it has performed. It will then use this cache for future visits to those sites until the entires in the cache have expired. THAT is why you're not seeing any difference.
17-10-2015 8:00 AM
The router itself won't need to look up a hostname very often, ntp.plus.net (network time synchronisation) and acs.plus.net (auto setup) are the only ones I can quickly think of. The router's DNS client does not affect devices attached to the router, only the router itself.
17-10-2015 10:40 PM
Quote from: ejs The router's DNS client does not affect devices attached to the router
So if the PCs on the network have their DNS server set to the router, you're saying that the router won't lookup anything and supply a data packet back to the PC?
Oh heck.. my understanding of DNS is completely shot! I better stop working on my dns server with internal resolver....
18-10-2015 6:20 AM
No, they are two separate subcommands in the Technicolor firmware:
dns client
dns server
The "dns client" is configured to use 127.0.0.1 as its DNS server, so that means dns lookups originating from the router itself get sent to the same dns server, the router itself, that is used by devices on the LAN.
dns client
dns server
