System files unaccessible
- Re: System files unaccessible
07-08-2007 9:54 AM
My system is a Fujitsu-Siemens Celsius R610 Workstation running Win XP Pro.
Any help gratefully received.
NC
07-08-2007 10:05 AM
It is a rather random fault.
07-08-2007 10:54 AM
I've tried what you suggested but the same thing happens - screen goes blank, rebuilds itself but nothing opens.
Any other ideas?
NeilC
07-08-2007 10:56 AM
07-08-2007 10:20 PM
Go to the Run box on the Start Menu and type in:
sfc /scannow
This command will start the Windows File Protection service to scan all protected files and verify their integrity, replacing any files with which it finds a problem. You will need your Windows CD.
Have a look at this from Microsoft (probably not relevant, but you never know!):
http://support.microsoft.com/?kbid=308421
Have you checked for viruses and malware?
Regards
Neil
07-08-2007 11:45 PM
Login with the new account and see if its ok.
Can you access the system from a cmd prompt and use dir etc?
08-08-2007 8:05 PM
I've run the scan programme which went through a check but didn't actually come up with anything. After it did its thing it just stopped - no messages, nothing just disappeared - nothing changed still the same problem.
I started in Safe Mode and lo & behold I could access ALL the folders - what does this tell me - feels like I'm nearer solving the problem - please tell me I am!
Best regards NeilC
08-08-2007 10:20 PM
Regards,
Neil
09-08-2007 11:53 AM
I also removed some old Java Runtime stuff - does Windows use Java in any way to operate/see system files?
Thanks again for all your help.
NeilC
09-08-2007 11:48 PM
10-08-2007 8:31 AM
There does not seem to be a definitive answer anywhere. Although there are a few suggestions of things to try there doesn't seem to be any feedback that any of them worked.
If you right click on Windows Explorer (for example) and select 'Properties' what does it say in Shortcut - Target?
Apart from what's already been suggested here, I'm running out of ideas. You could try re-installing Windows over your original copy, I don't hold out much hope with this one though!
Back up data, reformat and reinstall? ... but I expect you'd already thought of that.
Regards,
Neil
10-08-2007 9:32 AM
I fixed a similar-ish issue with a friends PC.
Basically whenever you tried to go in to the system32 folder, go to an antivirus website or go in to administrative tools the malware would just close the offending program.
In your case it sounds like it is killing explorer.exe which would cause all icons to disappear along with the taskbar and any explorer windows open. They'd then re-appear shortly after.
The way I fixed it may be a little tricky if you do not have a second computer.
Basically I downloaded Avast antivirus on a second machine and copied across the network. Then installed it on the affected machine (luckily it didn't kill the installer). Avast scheduled a boot-time scan which ran before windows started and picked up no less than 23 malware programs.
An existing piece of antivirus software doesn't necessarily mean this is automatically a non-issue because my friend had Trend Micro Antivirus installed.
No guarantees but I guess it's worth looking at.
10-08-2007 10:00 AM
Samurai - yes I have tried creating and logging on with a different account but no luck there either
Njal - when I right click Explorer it DOES say Target in shortcut and the Target is listed as - %SystemRoot%\explorer.exe
If I click below in 'Find Target' screen goes blank............
Does this explain anything?
I've also tried system restore to several past points but to no avail.
I'm a photographer and this is my main system and I can't afford for it to be out of action. At present I'm able to work and see all my files through Photoshop Bridge. But obviously this problem is severely curtailing my ability to access/sort/create folders etc.
10-08-2007 1:43 PM
That's what it should say.... just checking!
What happens if you Press:
Start - Run - and enter 'explorer' (without the quotes) into the 'Open' box and press OK?
What happens if you right click on the 'Start' button and click 'Explore'?
Have a look at:
Google Group
Regards,
Neil
cp:blue Over long URL concerted to a link. mod:end
10-08-2007 2:06 PM
http://support.microsoft.com/kb/918165
