System Restore
valart
System Restore
I tried to do a System Restore but after I ran the restore a message said the restore point was damaged and the restore did not happen because of this can anyone help me with this problem.
1 REPLY
computing50yrs
Re: System Restore
Hopefully there will be more than restore point, if you look at the restore window there is a tick box to show more restore points /dates. You may find one that works at an earlier date or time. I often find this and sometimes have to go back quite a way before finding one that works
