System Restore
- System Restore
System Restore
28-12-2013 7:46 PM
Is this normal for System Restore? What else should I expect to see? Anything else I should try?
Re: System Restore
29-12-2013 8:48 AM
Re: System Restore
29-12-2013 12:16 PM
you certainly shouldn't be having blue screen problem's with a restore point.
Re: System Restore
29-12-2013 12:22 PM
This is why I have regular full backups with Acronis on both my computers (one XP one Win 7)
Re: System Restore
29-12-2013 2:32 PM
However, there is one curious thing. According to Windows Security Center on the laptop, Microsoft Security Essentials is reporting it is Off, but when I click on the Microsoft Security Essentials icon at the bottom of the screen, Microsoft Security Essentials states that it is On. How do I get Windows Security Center to also say that Microsoft Security Essentials is On?
Re: System Restore
29-12-2013 2:53 PM
Is there an Avast "cleanup" tool that removes all traces of it?
If so, I'd remove MSE, then run the Avast cleanup and finally reinstall MSE with fingers crossed. Lots of boots in between.
You might even (if you dare!) reinstall and remove Avast at a suitable stage (with NO other A/V installed at the time).
Re: System Restore
29-12-2013 4:08 PM
Make sure you update and run a full AV Scan with Avast
Run a few online AV scanners
D/load and install the free version of Malwarebytes to make sure that no malware could be affecting and interrupting any of the system restore core file(s)
D/load the setup files of your preferred choice of AV from only the AV makers website
You must remove the old resident AV In this case Avast (Avast Removal Utility)
I have been using Avast for many a year and not had any issues other than having to redeploy the latest set of updates or program update where required after a M/S system restore
Disconnect from the internet to prevent any possible remnant of malware etc from calling home to install more malware etc
Reboot PC
Open command prompt with right click > Admin Privileges > Type "sfc /scannow" without the quotes ( notice the single space between sfc and the /)
Try system restore if still required,
if it still fails try running it in Safe mode (make take longer to run but usually affective)
Install fresh AV (reboot PC if / when it asks)
Re: System Restore
29-12-2013 5:28 PM
Incidentally, since removing Avast using the "Control Panel/Add or Remove Programs", I uninstalled Microsoft Security Essentials, then loaded the avastclear.exe, went into Safe Mode, and ran it. I then rebooted, and reloaded Microsoft Security Essentials, but there is no change - Windows Security Center still states that Microsoft Security Essentials is reporting as "Off".
Re: System Restore
29-12-2013 7:09 PM
I have dealt with these type of issues many a time
The above may appear to look like overkill,
however, we have to eliminate any possible malware that could be causing your issue(s)
Re: System Restore
29-12-2013 11:32 PM
Re: System Restore
30-12-2013 8:58 AM
Re: System Restore
30-12-2013 2:58 PM
Thanks to all, particularly TORPC. Happy New Year everyone
Re: System Restore
30-12-2013 4:10 PM
Your more than welcome
Glad to see you finally up and running
for some strange reason M/S SC does not like to play nicely with some AV Vendors Avast not being the only 1 tbh
My thoughts and are the same as several others are
M/S wants you to only use their product
I have seen this happen on test rig(s) with only a fresh install of M/S Operating Systems and their own built in programs, and a fresh install of AV, eliminating conflict(s) from 3rd party programs
May 2014 be a happy trouble free surfing and computing year for all of us
Happy new year to all from TORPC Towers xx
