System Restore on Windows 10
- System Restore on Windows 10
02-08-2015 12:48 PM
Re: System Restore on Windows 10
02-08-2015 2:22 PM
02-08-2015 3:54 PM
02-08-2015 4:37 PM
But even after i enabled it I can confirm updates no longer create a restore point.
02-08-2015 4:55 PM
02-08-2015 7:25 PM
Quote from: sjptd Maybe the 10 updates so far have all been the kind that don't need restore points.
You mean the kind that could not possibly ever misbehave on any computer?
02-08-2015 8:39 PM
No, I mean the kind that Microsoft considers should never misbehave, and so doesn't make them create a restore point before installing.
(I tend to rely on EaseUS backups rather than restore points anyway, but I notice when it does create restore points because of the extra time it takes.)
02-08-2015 11:28 PM
03-08-2015 1:30 AM
Think I'll be sticking with my trusty old 7....
03-08-2015 4:45 AM
I installed 10 on a spare PC yesterday and it's too gimmicky. I'll trim the start menu as a test. What do I want with Candy Crush on a desktop!
When it's new PC time in 2019/20 hopefully it's bedded in.
03-08-2015 9:20 AM
03-08-2015 9:44 AM
One feature of 10 that will be really useful to me is the screen recorder, which seems to work pretty well in all situations I have tried.
I had FRAPS and Nvidia ShadowPlay, but both of those were temperamental and did not work in many situations.
03-08-2015 12:01 PM
