Syntax Era
Euge
Syntax Era
No that wasn't a spelling mistake, it's a programme coming to BBC 4 later this year.
Syntax Era
Unfortunately I was 6 by the end of the 80's, but this programme is going to dramatize the battle between the spectrum and BBC micro which some of you guys out there might remember. Not that you're old or anything  Wink
Martin Freeman from The Office and Alexander Armstrong of Armstrong & Miller fame are enough to get me at least interested in giving it a watch. How about yourselves?
15 REPLIES 15
198kHz
Fixes: 41
Re: Syntax Era
As an early BBC-B adopter, I'll be watching out for that. Thanks for the tip.  Smiley
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Strat
Fixes: 565
Re: Syntax Era
Many of us are certainly old enough unfortunately. I also had some BBC Model 'B's.
Fixes: 1,483
Re: Syntax Era
I had an Acorn Electron.. aka cheap B.
I'll be watching.
Euge
Re: Syntax Era
I did have a Commodore Amiga 1200.
Another one that was basically a tape player but I can't remember what that was called.
James
Re: Syntax Era
I had an A500 Smiley
That was after our BBC Micro.
Strat
Fixes: 565
Re: Syntax Era
OK....I had a ZX81....with a 16k Ram Pack Tongue
...and I've still got it.
pierre_pierre
Re: Syntax Era
I have A UK101 http://www.gifford.co.uk/~coredump/uk101.htm and an Atmos http://www.48katmos.freeuk.com/whatisan.htm and an old drum type printer all still in working order, plus a printer for the Atmos that take four ball point pens
Strat
Fixes: 565
Re: Syntax Era
Beaten into submission Cry Wink
MauriceC
Resting Legend
Fixes: 17
Re: Syntax Era
I got the BBC 'B' along a long path from Nascom1 ----->  Nascom 2 --------> Amstrad 1640 (with TWO floppy drives!) ------->  Model 'B'
With a couple of colleagues even got it to support a HUGE 10Mbyte Hard Drive via a Home Brew interface on the TUBE and a much bastardised CPM Disk Driver software in Sideways ROM / RAM.
Ain't life easy with PC's these days.   Crazy
I guess that with the perceived Technical skills of the presenters, I'll give the prog. a miss. Undecided
Maurice
mal0z
Re: Syntax Era
I never succumbed to the Beeb PC - mainly as it had a 6502 processor and I had leant Z80 code on my Nascom 2 - adding a CP/M floopy system later.
Before that I had built the Wireless World computer in 1979 ( http://en.wikipedia.org/wiki/PSI_Comp_80_(computer) ) in the company lab.
Then first PC was the Amstrad 6128
Strat
Fixes: 565
Re: Syntax Era
I learned Z80 code on the ZX81but the Beeb had so much software available.
Denzil
Re: Syntax Era
Ah, another nostalgia thread  ;D. I started on a Commodore VIC20, which had 3.5KB RAM. Yes, that's 3.5KB. Software was initially loaded by typing in the BASIC code line by line, usually copied from a magazine. We then bought a cassette tape drive, which would still take a few minutes even to load 3.5KB.
pierre_pierre
Re: Syntax Era
Ah Yes I remember it well
My first IBM Type desk top had a massive big Hard disk, all 25Mb of it, and it ran Autoroute and spreadsheet and word processing
Strat
Fixes: 565
Re: Syntax Era
Autoroute.....that got everywhere.
I'm sure it would run on an Abacus Cheesy
