Syntax Era
- Re: Syntax Era
Syntax Era
01-07-2009 12:50 PM
Syntax Era
Unfortunately I was 6 by the end of the 80's, but this programme is going to dramatize the battle between the spectrum and BBC micro which some of you guys out there might remember. Not that you're old or anything
Martin Freeman from The Office and Alexander Armstrong of Armstrong & Miller fame are enough to get me at least interested in giving it a watch. How about yourselves?
Re: Syntax Era
01-07-2009 1:08 PM
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Re: Syntax Era
01-07-2009 1:22 PM
Re: Syntax Era
01-07-2009 1:26 PM
I'll be watching.
Re: Syntax Era
01-07-2009 1:34 PM
Another one that was basically a tape player but I can't remember what that was called.
Re: Syntax Era
01-07-2009 1:38 PM
That was after our BBC Micro.
Re: Syntax Era
01-07-2009 1:40 PM
...and I've still got it.
Re: Syntax Era
01-07-2009 1:44 PM
Re: Syntax Era
01-07-2009 1:47 PM
Re: Syntax Era
01-07-2009 1:48 PM
With a couple of colleagues even got it to support a HUGE 10Mbyte Hard Drive via a Home Brew interface on the TUBE and a much bastardised CPM Disk Driver software in Sideways ROM / RAM.
Ain't life easy with PC's these days.
I guess that with the perceived Technical skills of the presenters, I'll give the prog. a miss.
Maurice
Re: Syntax Era
01-07-2009 1:57 PM
Before that I had built the Wireless World computer in 1979 ( http://en.wikipedia.org/wiki/PSI_Comp_80_(computer) ) in the company lab.
Then first PC was the Amstrad 6128
Re: Syntax Era
01-07-2009 2:02 PM
Re: Syntax Era
01-07-2009 8:33 PM
Re: Syntax Era
01-07-2009 9:19 PM
My first IBM Type desk top had a massive big Hard disk, all 25Mb of it, and it ran Autoroute and spreadsheet and word processing
Re: Syntax Era
01-07-2009 10:22 PM
I'm sure it would run on an Abacus
