Synology Routers
- Re: Synology Routers
Synology Routers
24-02-2017 8:58 PM
anyone had a look at the routers that synology now make?
they look quite interesting and feature rich, and use the same software style as their NAS devices.
they don't have built-in modems though, so would mean a 2 device set-up.
24-02-2017 9:06 PM - edited 24-02-2017 9:10 PM
SmallNetBuilder were unimpressed with its performance when they tested it IIRC.
Edit - SNB Review
https://www.smallnetbuilder.com/wireless/wireless-reviews/32960-synology-rt1900ac-router-reviewed
24-02-2017 9:15 PM - edited 24-02-2017 9:16 PM
i looked at another review and they also noticed some performance issues with early versions, but those issues went away with a newer software release - https://www.youtube.com/watch?v=xxUDBM88jpM
looking at the date of the review that might be the reason for those issues.
