Syncing two Apple TV 64Ks
FIXEDTopic Options
- Syncing two Apple TV 64Ks
02-04-2020 12:10 PM
I've just taken delivery of another Apple TV for my bedroom but is there anyway I can synchronise the two devices I have so that all account details for apps such a Prime and BritBox are copied over, as these use a different email address from my Apple ID. The device is installed and ready but when I use either of these apps I'm asked to sign in, and entering them with the remote is a huge task.
If not then is there a way to use my iPad as the input device when entering the username and password details?
Fixed! Go to the fix.
1 REPLY 1
02-04-2020 12:18 PM
Yeah you can use the iPad. I use iPhone and iPad as input device.
1Password also works with using them as in input device too.
It should be automatic - but if not you have a remote icon in control centre that will connect to you ATV
