Synchronizing between computers
the_groundsman
I have all my music on my desktop, but backed up on an external hard drive attached to a different PC. Every so often I back up the music ( and pictures and EMails ) to this drive by copying them manually. I have mapped the external HDD as a separate drive in explorer.
I thought there was a way of synchronising the 2 in windows (XPSP2) but having found something called synchronise manager (and read the windows help) I'm none the wiser. I've shared my music but it and my other shared folders are not there to synchronise.
I have Home XP and the Windows Backup facility isn't in there. I have no Windows CD either as the OS was preinstalled
I wasn't looking to pay out for this function (I know many of you speak highly of the acronis product)
Copying stuff over manually is a chore and it would be great to automate it (in whole or part)
Fixes: 189
Re: Synchronizing between computers
I use a little application called synchbak se which allows me to automate synchs between 2 pc's and a nas box
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 62
I use SyncToy from Microsoft - currently using the v2 beta version as I am running on 64 bit Vista - and it does everything I need
linky
Fixes: 10
Windows breifcase does the job nicely for me...
the_groundsman
Perfect.
Thank you VERY  much
Synctoy does the job for me.
Robocopy is free and very fast as its dos based it can be run from a simple script and goes like billy wizz
get it from
http://www.microsoft.com/downloads/details.aspx?familyid=9d467a69-57ff-4ae7-96ee-b18c4790cffd&displa...
Or you can get a GUI version if you dont want to script it from
http://www.janwright.co.uk/robocopygui.zip
dgreen007
atbs1
We use GoodSync between 3 pc's
