Switching off TABS in IE7
Fixes: 19
I have got IE6 running at the moment, I am also running Firefox....
I did upgrade to IE7 but didn`t like the tabs, so reverted to IE6.
When I first ran Firefox, it had tabs, but I found out that it was/is possible to disable/switch off the tabs when browsing.....
Question.... Can you switch off/disable tabs in IE7?
(if so,  how?)
thanks
minkey
Re: Switching off TABS in IE7
Its
Tools -> Internet Options -> General -> Tabs -> Settings
You can turn it on and off there
Jeff
alanf
Select Tools then Internet Options
Under the General tab click on the Settings button by Tabs.
Uncheck Enable Tabbed Browsing
Press OK a few times and exit IE7.
When you restart IE7 the tabs will have gone.
[edit](You wait 3/4 hour for an answer to come along then two come along at once)[/edit]
Fixes: 19
O.K. Chaps.... Thanks very much..... will go away and play with IE7 now....  got to have it sooner or later I suppose, so might as well get used to it.....
Now I know how to do it, I`ll check out the missus laptop, as she doesn`t seem to know, (even after telling her zillions of times) to close the pages she isn`t interested in anymore...
