Switch to work with Thomson TG585?
Just checking for recommendations, for use with my router. Im hoping any would be fine so may just go for this:
Re: Switch to work with Thomson TG585?
Switches are pretty much universal, so any switch should work fine with any router (I've not heard of any problems though YMMV). The only suggestion I'd make is to consider a gigabit switch - but that's only if you have more than one computer networked *and* you regularly transfer large files between them. It'll be a bit more than a fiver though, that's a cracking price.
Hope that helps,
