Switch to work with Thomson TG585?
- Switch to work with Thomson TG585?
12-05-2011 11:12 AM
Just checking for recommendations, for use with my router. Im hoping any would be fine so may just go for this: http://www.amazon.co.uk/TP-Link-Unmanaged-Desktop-TL-SF1005D-Plastic/dp/B000FNFSPY/ref=sr_1_1?ie=UTF...
1 REPLY 1
Re: Switch to work with Thomson TG585?
12-05-2011 11:17 AM
Switches are pretty much universal, so any switch should work fine with any router (I've not heard of any problems though YMMV). The only suggestion I'd make is to consider a gigabit switch - but that's only if you have more than one computer networked *and* you regularly transfer large files between them. It'll be a bit more than a fiver though, that's a cracking price.
Hope that helps,
Hope that helps,
