Switch from Windows to Mac
- Re: Switch from Windows to Mac
17-12-2014 2:48 PM
I want to move away from using a Windows PC and start using an Apple Mac. Will I need to go on a course to learn how to use a Mac or is it straight forward
7 REPLIES 7
17-12-2014 2:50 PM
i picked it up very quickly, you don't need a course.
if you get it from an Apple store someone will take you through the basics.
17-12-2014 3:39 PM
What is the reason for the move?
18-12-2014 1:10 AM
I made the switch years ago with ease. In the end the basics of a GUI are not that different. Google for common replacements to Windows software you're used to. And cheapest way to make the switch is a Mac Mini, so you can use your old keyboard/mouse/screen.
Ts,
PhiL
Ts,
PhiL
18-12-2014 1:41 PM
The cheapest way is to load Linux onto your PC, it has a selection of GUI's!
Cost = zero
Cost = zero
18-12-2014 2:23 PM
the cheapest way to run OS X is run Linux? even for you that's a nonsense.
18-12-2014 6:46 PM
Quote from: vilefoxdemonofdoom The cheapest way is to load Linux onto your PC, it has a selection of GUI's!
Cost = zero
The op clearly states he wants to use an Apple Mac
19-12-2014 7:11 PM
Hackintosh, saves buying an entire mac, can run the MacOS on PC hardware aswell as giving you the option to dual or tri-boot between Windows, MacOS and Linux (if required)...
