Supporrt CD for ASUS motherboard A8N-SL1 Deluxe
paulo
Does anyone have a copy of the Support CD supplied with the ASUS motherboard A8N-SL1 Deluxe?
I am desperate to get hold of a copy so any help would be much appreciated.
I have already looked unsuccessfully on the ASUS website.
I can resist everything except temptation.
1 REPLY
paulrwselby
Re: Supporrt CD for ASUS motherboard A8N-SL1 Deluxe
@paulo
I have had a look and found the two CD's that came with my Asus SLI. One is all the utilities and drivers, the other is for the Wi-Fi PCI board which is a plug in separate card supplied with the M/B.
If you PM me I can perhaps arrange to send them to you.  Do you need both?
Paul.
