Superglue
7up
Fixes: 17
Superglue
Cyanocrilate / whatever you want to call it..
Word of caution.. if you get a usb plug that splits in half, the glue isn't the best stuff to use to put it back together lol. Try epoxy resin or something else.
Yes, I super glued a cable into a usb socket lol. I forgot it stays in liquid form until squeezed between two surfaces.. turns out that nice big blob i put in there under the cable must have leaked forwards into the plug Roll_eyes
Took some considerable effort to pull it back out with pliers... it was only that cheap tat from poundland with Tommy Walsh on the front but by god its strong!
