Suggestions and help with buying a cover for my ipad
- Suggestions and help with buying a cover for my ip...
18-08-2010 10:58 AM
Thanks for any help or advice.
Personal thought at a price of £429 surely they should have included a decent cover in the price. If apple keeps it up they are going to go from the most loved it co to the most hated. Just like Microsoft when they dominated the market apple is getting very greedy and is caring less what its customers think (remember the recent i phone fiasco). Best not reply to this part apple might sue us all in a class action
Re: Suggestions and help with buying a cover for my ipad
18-08-2010 1:23 PM
As far as cases for the iPad go, I can't offer much advice as I don't actually use a case with mine. It might however be worth considering Apple's own case? It's not the best – I've heard it starts to look a bit grubby after a while – but it's practical and not too expensive as iDevice cases go. (Plus it's easy to source.)
For other ideas, you could try taking a look at Macworld UK's iPad accessory reviews here.
18-08-2010 1:35 PM
18-08-2010 1:40 PM
19-08-2010 1:25 AM
25-08-2010 1:17 PM
After much research by my son he bought me the following i pad cover for my birthday. Snugg leather case cover and flip stand £29.99 from amazon there are more expensive ones but this fits the bill for me. Below is what i told him about it as he lives in london and i am in north east. I thought others may read this and also be looking for a cover I am not connect to either co
The cover is perfect and the magnets hold it in position when closed all inlets and outlets are cut out so you can get at them easily and it feels more comfortable when reading as it is not slippy like the i pad on its own. The stand works well and easy to use and would be a good angle to type or watch films etc. It is leather and looks quite posh. Altogether a nice piece of kit which i would definitely recommend.
26-08-2010 8:08 AM
a "Steering Wheel Laptop Holder" http://www.electronicsweekly.com/blogs/engineering-design-problems/2010/06/i-cant-believe-someone-ma...
If you want to buy one, they are available from Amazon !!! - http://www.amazon.com/AutoExec-WM-01-Wheelmate-Steering-Wheel/dp/B000IZGIA8/ref=cm_cr_pr_product_top
10-09-2010 3:42 PM
10-09-2010 5:08 PM
Quote from: purleigh Now you have your iPad case, maybe you need the next essential accessory ? -
Quote Product Features
* Image May Vary - Please See Product Title for Actual Size and Color!
* Please measure your steering wheel before ordering.
* Your steering wheel must be 1¼ inches in diameter or less
* Wheel Mate easily attaches to the steering wheel of your car
* Ideal for your laptop computer, as a writing surface, or lunch tray
10-09-2010 5:25 PM
I think they meant the diameter of the steering wheel grip, rather than the diameter of the wheel itself !
Did you look at all the photos on the Amazon link ? http://www.amazon.com/AutoExec-WM-01-Wheelmate-Steering-Wheel/dp/B000IZGIA8/ref=cm_cr_pr_product_top
I like how it starts with product pictures, and ends in pictures of car crashes !
15-09-2010 3:46 PM
