Sudden error message regarding not finding Proxy server
Averagejoe
some random messsage staeted coming up on my sons laptop on IE and Chrome every time he tries to load the internet, along the lines of, we cannop find/locate etc. Proxy server.  This isn't soemthing we've enabled by choice so before i cerate havoc do anyone have any advice or past experiecne on this.  AFAIK it was fine 2/3 days ago.  He hasn't downloaded anything that he can remember.
4 REPLIES 4
pjmarsh
Fixes: 18
Re: Sudden error message regarding not finding Proxy server
I've come across this on someones laptop before.  I found a load of malware on there which I cleaned up, and removed the proxy server settings and all was then ok.  I put the proxy setting changes down to some of the malware that the user had installed.
Averagejoe
pjmarsh, is this likely to be somehing the free versions of malwarebytes can handle or better to take it in to the shop?
pjmarsh
Fixes: 18
It was malwarebytes that I ran, and that did the job for me.
Averagejoe
thanks I'll give it a go.
