Sudden error message regarding not finding Proxy server
- Re: Sudden error message regarding not finding Pro...
28-05-2015 11:44 AM
some random messsage staeted coming up on my sons laptop on IE and Chrome every time he tries to load the internet, along the lines of, we cannop find/locate etc. Proxy server. This isn't soemthing we've enabled by choice so before i cerate havoc do anyone have any advice or past experiecne on this. AFAIK it was fine 2/3 days ago. He hasn't downloaded anything that he can remember.
4 REPLIES 4
Re: Sudden error message regarding not finding Proxy server
28-05-2015 11:47 AM
I've come across this on someones laptop before. I found a load of malware on there which I cleaned up, and removed the proxy server settings and all was then ok. I put the proxy setting changes down to some of the malware that the user had installed.
28-05-2015 11:55 AM
pjmarsh, is this likely to be somehing the free versions of malwarebytes can handle or better to take it in to the shop?
28-05-2015 11:58 AM
It was malwarebytes that I ran, and that did the job for me.
28-05-2015 12:00 PM
thanks I'll give it a go.
