Successfully set up Hub One with a USB HDD..........but
actualityplus
I can now access this network HDD with my laptop, but can I set up an IPad Pro to do the same? I do not use iCloud or similar. Thanks in advance
3 REPLIES 3
Fixes: 1,483
Re: Successfully set up Hub One with a USB HDD..........but
Moderators Note
This topic has been moved from General Chat to Tech Help.
Fixes: 1,483
I'm pretty sure that the answer is no.
The Hub One only supports SMB 1, if memory serves correctly,  and doesn't support SSH.
actualityplus
After a sleepless night......Problem sorted by accident!
I can now read files contained on the USB network hard drive, connected to Hub One, using my iPad Pro.
I can read documents/photos after downloading Documents by Readdle App for iOS
just checking out the VLR app for watching films
zzzzzzzzz
