Stylus pen and app for android tablet
- Re: Stylus pen and app for android tablet
14-04-2015 8:36 PM
For ease I want to be able to take notes at some meetings I'm due to attend soon but don't want the hassle of pen and paper. My Acer 8" tablet didn't come with a stylus pen so am wondering whether it's just a case of buying a pen (they seem to range from a few squid to over £50) and installing an app?
Does anyone have any recommendations?
Thanks.
Forum Moderator and Customer
14-04-2015 9:06 PM
the only android device that I know of which can be used a a notebook is the galaxy note (which comes with its own stylus pencil) most capacitive touch screens wont recognise a pen type stylus only the big bulbous things you get free with the cheap Chinese cases and screen protectors
unless your planning on spending over £100 on a proper digitizer pen that's designed to work with you specific tablet/
14-04-2015 9:21 PM
What could be less hassle?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
14-04-2015 9:46 PM
Carrying it around, getting creased, pages out of order, losing pages - so many things with me
Quote from: Force Pen & paper? Hassle?
Voice recorder? But then I'd have to transcribe it.
Quote from: Force What could be less hassle?
Further research and it seems that Acer do a couple of capacitative pens suitable for use with the A-840FHD. This is one of them
I have emailed them to confirm their suitability.
15-04-2015 9:37 AM
a lot cheaper and if you loose one you still have more to use
all capacitive stylus's are the same fat and horrible to write with, the only thing that looks like a pen and has a thin tip is a digitizer and iirc they come with surface pro devices or with the galaxy note http://www.ebay.co.uk/itm/Touch-Screen-Capacitive-Stylus-Replacement-For-Samsung-Galaxy-Note-3-S-Pen... there cheap enough that you could buy one to see if it works but personally I doubt it will since I've had a plethora of these type of devices and they don't work on most of the smart phones /tablets I've tried them on /
there's some info you might find useful here http://www.tabletpcreview.com/howto/how-to-use-a-stylus-with-your-tablet/ or you could try any of these thousands of info links https://www.google.co.uk/?gws_rd=ssl#q=best+stylus+to+write+on+acer+8%22+android+tablet
15-04-2015 9:48 AM
I found it awkward to use so don't.
