Struggling to connect to the internet
Fixes: 20
Setting up XP .... got the wireless driver working... and am connected to the router via wireless....
got a balloon message...
Windows was unable to find a certificate to log you on to the network  <ljs>
(<ljs> my wireless connection ssid)  not really but that is where it would be....
So what am I missing/doing wrong, and how do I correct it.. Please....
Fixes: 22
Re: Struggling to connect to the internet
Have you installed SP2 or SP3 yet? SP2 added WPA support and SP3 included the update for WPA2.
I always do installs and related updates using a LAN cable and I'd advise you to do the same.
Wireless I don't even look at until the end.
Fixes: 20
Yes Have done sp2 ..... just doing sp3 now.....
cant get sp3 to work.... as it is a .iso file on cdrom... windows xp does not recognise it.
Fixes: 20
OH dear.... Never mind chaps... I found the answer.....
Use the correct Network Key.....
(I forgot I had changed it from what it says on the bottom of the router....... now sticking a new label on there.... )
Doh !  Roll eyes
Fixes: 25
Quote from: shutter
An ISO file is supposed to be an image of the contents of a CD http://pcsupport.about.com/od/termsi/g/isofile.htm .  If what is on the CD is an ISO file itself then you made a mistake when creating ("burning") the CD.  Your burning software should have 'decompressed' the contents of the ISO file.
And if you can't figure that out just let Windows Update download and install it.  Wink
Fixes: 20
Yay !  now I got my wireless working... that is what will happen !... thanks guys
Wink
