Struggling to connect to the internet
- Re: Struggling to connect to the internet
22-08-2012 7:55 PM
Setting up XP .... got the wireless driver working... and am connected to the router via wireless....
got a balloon message...
(<ljs> my wireless connection ssid) not really but that is where it would be....
So what am I missing/doing wrong, and how do I correct it.. Please....
Windows was unable to find a certificate to log you on to the network <ljs>
7 REPLIES 7
22-08-2012 8:25 PM
Have you installed SP2 or SP3 yet? SP2 added WPA support and SP3 included the update for WPA2.
22-08-2012 8:28 PM
I always do installs and related updates using a LAN cable and I'd advise you to do the same.
Wireless I don't even look at until the end.
22-08-2012 8:29 PM
Yes Have done sp2 ..... just doing sp3 now.....
cant get sp3 to work.... as it is a .iso file on cdrom... windows xp does not recognise it.
22-08-2012 9:12 PM
OH dear.... Never mind chaps... I found the answer.....
Use the correct Network Key.....
(I forgot I had changed it from what it says on the bottom of the router....... now sticking a new label on there.... )
Doh !
Doh !
22-08-2012 10:06 PM
Quote from: shutter .... as it is a .iso file on cdrom...
An ISO file is supposed to be an image of the contents of a CD http://pcsupport.about.com/od/termsi/g/isofile.htm . If what is on the CD is an ISO file itself then you made a mistake when creating ("burning") the CD. Your burning software should have 'decompressed' the contents of the ISO file.
22-08-2012 10:23 PM
And if you can't figure that out just let Windows Update download and install it.
22-08-2012 10:28 PM
Yay ! now I got my wireless working... that is what will happen !... thanks guys
