Strange problem
- Strange problem
Strange problem
16-04-2014 8:13 PM
On the number pad, when num lock is on, the button 9 doesn't work when pressed normally. If I press and hold the 9, I get a list of 9's like 99999999999999999.
So to confirm, all the number keys work, and 9 did work. Now randomly when I press 9, it doesn't work, when I press and hold, it does work!
Re: Strange problem
16-04-2014 8:18 PM
Re: Strange problem
16-04-2014 8:32 PM
Keyboard cost £9.00 on ebay... and viewed a video on ebay... job took 15 minutes .... start to finish...
Laptop is Dell Inspiron 1545
Re: Strange problem
16-04-2014 8:44 PM
And nothing has been spilt Jim...
However.... when I press the button, it works! I just noticed that it opens/switches to another tab instead of typing the number 9. When I hold it down it gives me loads of 9's.
Re: Strange problem
17-04-2014 8:29 AM
Quote However.... when I press the button, it works! I just noticed that it opens/switches to another tab instead of typing the number 9. When I hold it down it gives me loads of 9's
I'm sure you have already checked this but is the language/region set correctly ? What you said above sounds like the keyboard might be set up for another language and that's why the 9 might be opening another tab on a single press
Re: Strange problem
17-04-2014 12:06 PM
I have no idea how to change it!
@gtowen no I didn't actually check the region as it was working a few days ago, but I just checked and it's set to the UK layout.
Re: Strange problem
17-04-2014 12:14 PM
However this program may well do it for you http://sharpkeys.codeplex.com/ although have a read here for other options http://lifehacker.com/5883003/the-best-key-remapper-for-windows
Re: Strange problem
17-04-2014 2:05 PM
I'll have a look when I get a moment.
Re: Strange problem
17-04-2014 5:36 PM
would that software be able to disable a Key ?
the Tilde key is always a pain,,, unnecessary
Re: Strange problem
17-04-2014 6:05 PM
Re: Strange problem
17-04-2014 6:40 PM
Quote from: rongtw the Tilde key is always a pain,,, unnecessary
The tilde ~ is used to indicate the home directory in script files.
Re: Strange problem
17-04-2014 7:16 PM
Quote from: Devonian I run through the diagnostics when I got home from work, and the 9 key actually is registered as the page up key.
Try pressing NumLock. On my full size keyboard with Num lock on the numbers work, with it off 7 is Home, 8 is Uparrow and 9 is pageup.
Check that the keyboard is set to the correct type - it sounds as if the OS thinks you have a 106 key keyboard (the kind with a keypad to the right) rather than the correct one for the laptop. Have you connected an USB keyboard to it at any point?
Clues at http://support.microsoft.com/kb/927824
Re: Strange problem
20-04-2014 6:30 PM
