Strange problem - XP Pro & networking
- Strange problem - XP Pro & networking
- « Previous
- 1
- 2
- Next »
Re: Strange problem - XP Pro & networking
02-12-2008 5:42 PM
This is certainly odd.... I take it your firewall isn't deliberately blocking access to the router?
02-12-2008 5:51 PM
I've since found that Teamspeak connects to my Teamspeak server on the internet & I've been able to talk to a friend on it. Using netstat, most connections are showing FIN_WAIT_1, where others (mainly messaging clients) are showing ESTABLISHED, but are not able to log in.
I'm beginning to think a reinstall is the only option but I really don't want to go down that route.
03-12-2008 11:16 AM
Sorted
I finally got around to installing Wireshark on the PC. After switching off all other network-aware programs I started Wireshark & used IE7 to try to get to my router's web interface. After it gave up I stopped Wireshark & found a TCP checksum error amongst all the data, it also suggested the culprit might be a setting on my network interface called checksum offload. After disabling this everything burst into life!!
Having said that, I can't get on to the www.avast.com website to renew my AV license, any chance someone can try this site?
03-12-2008 11:29 AM
Glad it's sorted, Avast site is working fine here though.
03-12-2008 11:34 AM
Well it looks like I'm still not out of the woods then
This is what I get when trying www.avast.com -
Connection Interrupted
The document contains no data.
The network link was interrupted while negotiating a connection. Please try again.
This is stupid, I can't even get to it on my laptop
03-12-2008 12:00 PM
What does a tracert give you for avast?
03-12-2008 12:06 PM
Tracing route to www.avast.com [74.86.245.119]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms gateway.local [192.168.2.1]
2 26 ms 38 ms 23 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 18 ms 18 ms 17 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 17 ms 18 ms 17 ms 80.239.193.141
5 17 ms 16 ms 19 ms cw-ic-122209-ldn-b1.telia.net [213.248.74.214]
6 19 ms 19 ms 19 ms bcs1-so-2-1-0.Londonlnx.savvis.net [204.70.193.1
18]
7 20 ms 17 ms 16 ms cr1-pos-0-0-3-0.londonuk1.savvis.net [204.70.192
.5]
8 147 ms 147 ms 154 ms cr1-tengig0-7-0-0.dallas.savvis.net [204.70.196.
213]
9 143 ms 142 ms 145 ms pr2-ge-4-0-0.DallasEquinix.savvis.net [204.70.20
0.169]
10 147 ms 147 ms 147 ms er1-te-3-1.dallasequinix.savvis.net [204.70.204.
149]
11 136 ms 129 ms 133 ms te1-1.cer02.dal01.dallas-datacenter.com [208.175
.175.10]
12 132 ms 134 ms 131 ms po2.dar01.dal01.dallas-datacenter.com [66.228.11
8.205]
13 136 ms 134 ms 134 ms po1.fcr03.dal01.dallas-datacenter.com [66.228.11
8.186]
14 133 ms 133 ms 132 ms www.avast.com [74.86.245.119]
Trace complete.
18]
.5]
213]
0.169]
149]
.175.10]
8.205]
8.186]
Trace complete.
03-12-2008 12:24 PM
The IP address I have for Avast is different, what do you get if you try http://75.125.246.130?
If that is OK you could try flushing your DNS cache by using ipconfig /flushdns and try it again
03-12-2008 12:29 PM
Thanks for that, I was able to get on to the site with that address & re-register Avast.
- « Previous
- 1
- 2
- Next »
