Strange behaviour of Win7 Premium
- Strange behaviour of Win7 Premium
25-10-2014 4:59 PM
Luckily I had a copy of the file but had to change its name to let me put it in its proper place in the index. These files re pages of addresses for the production of sticky labels (you might guess they are for Xmas!) all nicely in alphabetical order. I could not use the original file name because it was locked into the damaged one. I just changed the names of al the other files to agree with the new name style and save the whole lot, then deleted all the old files. Pause for breath.
One side effect which could be serious has been a regular backup failing to complete itself because a faulty file would not work. Could this be the one identified above?
Edit for typo.
Re: Strange behaviour of Win7 Premium
25-10-2014 9:47 PM
26-10-2014 1:01 AM
Only twice in my lifetime I have heard chkdsk referenced as the "Full Five Stage Version"
To clarify
Open up the command prompt (Click on start type in CMD) then right click on the Command Prompt Icon & choose Run as administrator
You will then be presented with the command prompt box with a black background
To run a standard chkdsk that only checks 3 stages in read only mode
Type chkdsk then press enter & it will then run 3 stages but not do any repair(s)
To run a Full Five Stage Version
As above open the command prompt
Then type chkdsk /f /r & press enter (notice the single spaces between the /'s) You will be informed that it cannot run as the volume is in use & do you want to schedule the volume to be checked upon next reboot
Press Y then press Enter then reboot your laptop (Can typically take approx 40 minutes on a clean machine, or if it needs to complete repairs can take several hours)
Do not be alarmed if it tells you that it has either Replaced / Deleted inserted orphaned MFT index files etc
Here is a brief list that show some results one may come across
Quote Deleting corrupt attribute record (128, "") from file record segment 120759.
The USA check value, 0x0, at block 0x3 is incorrect. The expected value is 0x63.
The multi-sector header signature in file 0x3d5b6 is incorrect.
Deleting corrupt file record segment 251333.
Deleting orphan file record segment 251321.
Deleting an index entry from index $O of file 25.
Deleting index entry P1040158123.JPG in index $I30 of file 118566.
26-10-2014 11:21 AM
27-11-2014 3:44 PM
I have not ventured down this path after consideratioon of the above advice yet. If you look again at my post you will see that getting a full backup is problematic. I am trying to trace the file(s) which might be corrupted, but it is not easy. (another thread on this elsewhere).
27-11-2014 8:20 PM
28-11-2014 12:45 PM
I will try to backup in sections of my files until I find the bit that will not work. At least that might finding the culprit a bit easier. Will report later.
08-01-2015 11:29 AM
1. SyncBack (www.2brightsparks.com) - this is great and there is a free version too. You can schedule it to make copies of your data and with the paid version to can backup to an FTP space. The free version does not backup to such as Google drive or OneDrive but this is a way around that. Now, if like me you like free stuff
2. Microsoft's own Backup system. This is of course free as it's built-in. I would recommend that you create a partition of your HD as the Windows Backup will use ALL the space it can get, eg create a partition that can comfortably store your data plus a bit. Windows will make backups to here for you. NOTE, remove the option to make a System Recovery Image as it will do this each time and you only really need one of these and I would create that as a physical CD to put away safe.
3. Macrium (http://www.macrium.com/reflectfree.aspx - this is my preferred choice) also a free version is available. This tool lets you create an entire image of a drive or partition. NOTE, you would have to create a separate partition to image the main 'C' drive, etc. I prefer this one because it has the added advantage that you can do it from Windows and the resulting image file can also be 'mounted' to view and copy files from if you need to without doing a restore. You can also (as I do) have multiple images of your drive and it also has a CD boot option in the event you have to restore the full HD image. Finally, it can also create entire clones of your HD - the ultimate backup!
PLEASE NOTE: in all cases, the above might say create a partition on your drive, etc, but if the drive fails, so will the backups! With that thought in mind, get a external USB drive or better still, invest a bit of cash and get a Buffalo NAS drive - it's well worth the investment as these drives can do more than just store files, ie DNLA certified media server, TimeMachine (Apple), Remote Access, multiple volumes and so on.
I do not work for any of the above and these are just my opinions and solutions. If you get stuck, I'll try to help but your best source is always the software or hardware vendors first. In any case, even a basic backup can save hours of re-installing and recovering data!
08-01-2015 5:31 PM
On the file issue, there is a utility called 'unlocker' that has freed up files for me that Windows refused to access, dven after tge 'take ownership' ploy
09-01-2015 12:59 PM
As a side issue, I have not resolved the reason why I get the occasional BSODs, always in conjunction with the printing of texts on my HP6100 printer which otherwise seems to do its stuff very well. I have had no responses from M$, HP or Lenovo indicating a possible explanation.
27-01-2015 12:59 AM
Quote from: Kremmen since Microsofts SyncToy let me down.
Urgh yeah i had a run-in with that once where it decided it was going to start deleting stuff that didn't need deleting. No idea how or why it decided it must do that but that was the end of it for me.
