Strange ARP output...
- Re: Strange ARP output...
14-08-2015 2:18 PM
Quote ~ $ arp
Address HWtype HWaddress Flags Mask Iface
ANDROID-52A17B268A37763 ether 14:a3:64:41:fb:b7 C eth0
TARDIS ether 2c:d0:5a:71:3d:93 C eth0
router ether a0:21:b7:87:56:18 C eth0
192.168.1.254 (incomplete) eth0
ENTERPRISE ether 00:0c:43:00:44:db C eth0
Isn't 192.168.1.254 the broadcast address?
14-08-2015 5:54 PM
Phil
14-08-2015 9:09 PM
bmon is quite funky as well.
15-08-2015 12:13 AM
15-08-2015 7:28 PM
15-08-2015 7:59 PM
15-08-2015 8:16 PM
15-08-2015 8:36 PM
15-08-2015 9:25 PM
- Stealth Mode connection attempt to UDP 192.168.1.180:58222 from 192.168.1.254:53
The AV firewall does this all on its own. The ports I presume. I don't know what either are.
Leaves the 224 ones alone.
15-08-2015 9:27 PM
15-08-2015 9:30 PM
15-08-2015 9:41 PM
16-08-2015 11:40 AM
My DHCP range is 192.168.1.3 - 192.168.1.100 (historical reasons).
Since that 192.168.1.254 address is in my Linux PC ARP cache (which has no anti-virus) it is very peculiar.
There are Windows machines lurking on my network though...
But as you say, it doesn't make any difference to anything.
BTW doing a
ping 192.168.1.254doesn't connect - but it puts it in my ARP cache.
I notice that a web page can effectively ping your local network devices - see http://stackoverflow.com/questions/4282151/is-it-possible-to-ping-a-server-from-javascript
16-08-2015 8:59 PM
Interesting .js stuff. Don't do apps (tho have been thinking (read:procrastinating) about it). Is all that necessary when building apps? Or just someone with time to spare?!
