Stopping Kontiki - Sky Player
Fixes: 62
If I install Sky Player it uses Kontiki to mess up my usage.
I understand that, even when you aren't using Sky Player, it continuously uploads.
Is there a relatively simple set of instructions somewhere for disabling it.
Fixes: 234
Re: Stopping Kontiki - Sky Player
Is it not just in the startup group?
Pretty sure the BBC one was and that used kontiki too.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 62
As I understand it the Sky system uploads continuously even when you aren't using the program.
One way round it is to use Task Manager to stop the processes khost.exe and kservice.exe
Fixes: 234
remove it from run and runonce in the registry then.
Fixes: 10
There was a utility that I had when iPlayer was P2P that dealt with Kontiki - now what was it called...?
Edit: Still struggling to remember/find it, which is annoying because it did all the TV downloaders (not just BBC) and it's exactly what you want. Sad
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 59
Was it kclean.exe? Not sure where one can get this though.
David
pierre_pierre
via Google
Forums - I'm trying to find kclean.exe - PC Advisor
3 posts - 2 authors
Expert PC help and advice including news, hardware reviews, forums, buying advice and software downloads from PC Advisor.
www.pcadvisor.co.uk › Forums › Helproom - Cached - Similar
Get more discussion results
Removing kontiki
10 posts - 6 authors - Last post: 14 Jul 2008
http://demo.kontiki.com/support/KClean.exe. You'll then be asked if you want to run the program twice. This varies a bit depending on your ...
www.skyuser.co.uk › ... › Other Sky help and support › Sky Player - Cached - Similar
There are 5 steps to getting Sky Anytime on PC:‎ - 9 May 2008
sky anytime requires that your computer is running windows xp - Page 6‎ - 17 Jul 2007
More results from skyuser.co.uk »
The PC Doctor's blog » Blog Archive » Remove Kontiki with KClean.exe
3 Mar 2006 ... It seems that Kontiki are going to great lengths to remove a lot of their links and downloads to the Kontiki removal tool KClean.exe (which ...
www.pcdoctor-guide.com/wordpress/?p=2487 - Similar
Kontiki - Wikipedia, the free encyclopedia
KClean.exe is a program that eliminates all Kontiki components. However, use of this program will eliminate everything Kontiki from the system and break the ...
en.wikipedia.org/wiki/Kontiki - Cached - Similar
BBC iPlayer plagued by problems - Times Online
31 Jul 2007 ... Some users reported being able to get the service to work by downloading a program called KClean.exe from the internet and then ...
technology.timesonline.co.uk/tol/news/tech.../article2173667.ece - Similar
Watch TV Online | Sky Player
Once you have used Kclean.exe, you will need to delete and re-install these programs to ... By downloading KClean.exe, you acknowledge that Sky is providing ...
skyplayer.sky.com/vod/content/Home/...is.../termsPage.do - Cached
Ask Jack, February 2 | Technology | The Guardian
2 Feb 2006 ... After that, run the KClean.exe program, which is available at www.bbc.co.uk/imp/email/KClean.exe, Download.com and other sites. DVD for CDs ...
www.guardian.co.uk/.../askjack.guardianweeklytechnologysection - Cached - Similar
Mary Blighthouse: Kontiki Delivery Manager on iPlayer, 4oD and Sky ...
The KClean software can be download from http://paul.damien.googlepages.com/KClean.exe if it has been removed from the BBC Website - Please ensure, ...
blog.maryblighthouse.co.uk/.../kontiki-delivery-manager-on-iplayer-4od.html - Cached - Similar
Fixes: 10
Nope - that's to remove it.
This was a program that would start and stop the service at defined times - and I still can't remember what it was called. It was downloaded from a blog page and I have a feeling it was northsomethingorother... but I could be totally confused with something else! Embarrassed
Fixes: 10
TV On-Demand Monitor developed by 7Northfield
The blog I got it from is now invited readers only: http://odmonitor.blogspot.com/ There's another blog associated with it http://thetechnophile.blogspot.com/ which is also blocked.
There's a download here: http://tv-on-demand-monitor.software.informer.com/ - but without access to the blogs I can't tell how up to date that is.
scootie
yep that's what i used  for 4od and iplayer in the old days
Fixes: 10
From remembering the name I found: http://community.plus.net/forum/index.php?topic=75393.0
... and yes Asbo Dog you posted in there also! So why didn't you respond to Jim's plea?
scootie
dropping kids of at skool and community site has only just come back up for me in past 20 mins and havent seen this thread till today,  i to on reading this thread couldn't remember the name but knew it was tvmon you was after.
i haven't used the app since 4od app closed down and went web browser only
Fixes: 10
2.2 does seem to be the latest - I've just found this: http://www.7northfield.com/7northfield/softwareupdates/tvodmonitor/
Fixes: 62
Thank you all - that seems to be exactly what I need  Grin Grin Grin
