Stopping Broadcast SSID on Sagem 2704N router
JR77
Hi, I am aware of, and have already disabled the broadcast of my primary SSID. However, can anyone tell me how to disable the second SSID, the one that is "PlusnetWirelessXXXXXX"? I have looked through the Expert_User.html page already and can't find anything. I though tI might be able to edit the config file, but it isn't a simple text file that I can edit.
Any ideas?
1 REPLY 1
Anotherone
Fixes: 21
Re: Stopping Broadcast SSID on Sagem 2704N router
Hi @JR77 welcome to the forum.
I haven't played with the 2704n recently, but IIRC you can't turn it off. I'm also assuming your "primary SSID" is another Router/WAP?
You can give it a single character name such as a . but as anyone in range will see the network anyway, having no name doesn't stop that, so just give it some obscure name of your choice.
