Starting Windows 7 in Safe Mode
Javert
Please can anyone tell me a way to start Windows 7 in Safe Mode?  I’ve followed the instructions from Microsoft - “Press and hold f8 as your computer restarts” - but to no avail.  I have tried this at least five times!  Cry
11 REPLIES 11
Mav
Fixes: 515
Re: Starting Windows 7 in Safe Mode
I think you may find repeatedly pressing the F8 key works rather than just holding it down.
Forum Moderator and Customer
HPsauce
Yes, I tap it "staccato"!  Cheesy
NedLudd
Quote from: Javert
Does it otherwise boot normally?
Geoff,
York.
Javert
Many thanks! I’ll try tapping away to Strauss’ “Pizzicato Polka”!  Windows instructions are, and I quote: “Press and hold the F8 key as your computer restarts”.  I want to remove my Kaspersky IS 2013 - and their instructions say to use their “tool” to remove it in Safe Mode.”  Smiley
Yes, it does boot normally.
Oldjim
Resting Legend
Fixes: 63
Doesn't the normal add/remove process work - the tool is only if that fails
shutter
Fixes: 65
Or you could try this.......
http://www.glarysoft.com/absolute-uninstaller/
have a shortcut on the desktop for it, and it is easier to access than the windows normal add/remove
quicker to load the list of programs installed, uses the same "look" as windows
rongtw
Fixes: 12
This is the best uninstaller out there  Wink http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
NedLudd
Have to agree there. Revo is the dogs bollards!
Geoff,
York.
Javert
Thanks for the replies - much appreciated.  Sorry, I couldn’t reply earlier as I had a 10 am pupil - and I have to concentrate if doing anything technical on my PC!
The “Staccato” Method worked! Is it similar to the Rhythm Method?  Cheesy
I removed the Kaspersky product using their “Removal tool” as I recall that removing by other Uninstall programs leaves parts behind - which have to be removed before you can install your new program. Using the aforementioned tool removes everything!  I do use the Revo Uninstall program for everything else.
HPsauce
Quote from: Javert
I've had to use the relevant "Removal Tool" on many an antivirus install, though very rarely to get rid of Kaspersky.
It's regularly the other way round though, a "properly removed" AV product (using normal Control Panel options) is still detected by Kaspersky which then refuses to install.  Crazy
Javert
It was because of stilly things like this that I decided to change products, after being with them for 15 years or more!
