Spyware Terminator
valart
Spyware Terminator
I have downloaded Spyware Terminator and I it found some viruses such as hyjacker and malaware,I wonder if anybody else has this program and is it any good I do notice that my startup is slower to begin,I wondered because my computer is seven years old this also makes things slow at startup
1 REPLY
Re: Spyware Terminator
A 7 year old computer will be slow especially if you have reinstalled in  a long time what are the specs?
If you have a couple of malware chances are you have more. can you find out whats running at startup by going to start \run\type msconfig and give us a list of whats running at startup.
Any AV product will slow startup as it will do some scans before it lets things load or do system checks
