SpyBot S&D 2
Fixes: 225
SpyBot S&D 2
Anyone else 'upgraded' to this?
Installed it yesterday and have found it to be extremely slow, overcomplicated and full of stuff I have no idea what to do with as it is not intuitive in the least.
Will probably revert back to 1.6.
Forum Moderator and Customer
Fixes: 62
Re: SpyBot S&D 2
Re: SpyBot S&D 2
@mav:- thanks for the heads-up, saves effort looking
to quote OJ link
In testing, it proved almost 100 percent ineffective.
I'm happy with 1.6
Fixes: 225
Re: SpyBot S&D 2
Quote from: journeys
I'm happy with 1.6
And that is what I'm returning to Smiley
Thanks for the links OJ.
Fixes: 24
Re: SpyBot S&D 2
I gave up on Spybot 1.6 some years ago because I found it too slow, so I hate to think what the new version is like.  I particularly hate the way it sometimes finds it cannot remove certain entries so asks to run again on start-up but when it does this it runs the complete scan again instead of going straight to deal with those entries it found the first time round.  If you want a quick but thorough spyware scan i would recommend either SuperAntiSpyware http://www.superantispyware.com/ (free edition) or Malwarebytes http://www.malwarebytes.org/ (free version).
Fixes: 225
Re: SpyBot S&D 2
I've never suffered with the problems you've mentioned, RR, with version 1.6. Maybe it was fast because of the SSD.
As for running again after start-up it simply completes what it couldn't do prior to reboot without doing a full scan once more.
