Spry Menu not viewing correctly in Firefox-Help!
- Re: Spry Menu not viewing correctly in Firefox-Hel...
15-10-2008 3:48 PM
Hi! Hoping someone can help me!
I've created a website that uses Spry menus as the navigation. I have just uploaded it, and it works fine i IE 7. Firefox and IE 6 are not displaying it properly, It only shows the last menu, and hides everything off screen. This did work, but i think i have changed something somewhere and its all gone wrong!
I can post my CSS code if it helps. the website in question is www.concept-data.com
Please help, I'm new at this and its really bugging me.
Thanks,
Nicole
Thanks,
Nicole
1 REPLY 1
Re: Spry Menu not viewing correctly in Firefox-Help!
15-10-2008 5:45 PM
Don't use ActiveX.
