Spoof a US IP address?
Hi Folks
CBS have a website that streams hundreds of classic US TV programs. http://www.cbs.com/classics Unfortunately I just get a message saying none of it is available. I am guessing this is because I don't have a US IP address. I would love to watch some of these old shows, anyone know an easy way around this?
Peace be with you.
Re: Spoof a US IP address?
use a free proxy base din the states if thats what it is. There are hundreds if you search Google for free proxy
Fixes: 69
This will probably work.
Plusnet Products Team
aw shux.  nowt for linux.  i'd like to be able to watch some of those films too.
I have tried several proxy addresses with no luck, in fact I cant connect to anything once I use a proxy address. I have to remove it to see any web site.
Friends in Spain have the same problem with the BBC iplayer.  They get round it by using a proxy.
Quote from: artificer
Dual Boot is your friend  Wink
Quote from: God
Peace be with you.
And also with you.
Proxy will work but try
http://www.vnunet.com/vnunet/downloads/2164800/torpack its a browser which tunnels via another network
or try
http://www.proxylord.com/ you dont change anything on your setup just put in the url you want to see or try
http://www.megaproxy.com/freesurf/
or another one
http://www.the-cloak.com/login.html
Tried them all (except the first which required a program install) with no luck.. ah well, thanks for trying.
thanks for trying samuria.  i had no more luck than god.
