Speedtouch 585 V6
PhyllisTyne
Speedtouch 585 V6
Thinking of buying one of these. can someone confirm the front button can be used to turn the WLAN on and off? Or should I just avoid this router like the plague?
TIA
PT
15 REPLIES 15
Fixes: 167
Re: Speedtouch 585 V6
I've actually got one of these but never tried pressing the button on the front  Roll_eyes
I can't recommend this router enough, holds my line perfectly and had very few issues.
 Chris Parr
 Plusnet Staff
PhyllisTyne
I have been told that if you hold the button for a few secs in turns WLAN on and off. would like to know if its true if you get a minute.
TIA
PT
Fixes: 167
I'll try tonight if nobody else tried this first.
 Chris Parr
 Plusnet Staff
Fixes: 7
I think that's similar, if not the same model as I use. I can recommend it also, as it's been fine for me .. only router I've had which I've never had to reboot to regain a connection.
I've never used the front button either, but from a look at the manual it is a wireless client association button, rather than just a means to turn the wireless off. As I never use it, I don't know how it works, but the manual will explain more. You can download it from here.
Still I am pretty sure you could just disable it within the settings anyway, so don't let that put you off!
PhyllisTyne
Thanks, had read the manual previously but it is not clear whether you can get a temporary or permanent turn off of WLAN using the button. I would like permanent on/off facility. I know I can turn most routers off via their settings but I don't always have my PC on and its a pain to boot just to do it. The reason I would like it is that my WLAN interferes with a box I have for transmitting TV around the house, so I just want to turn it off on demand.
PT
Fixes: 167
Embarrassed
I forgot to check this last night Sad
 Chris Parr
 Plusnet Staff
pnf
Page 87 of the User Manual for the Thomson Speedtouch 585v6 (4.6.5 Access Point Settings) refers to the following configuration information:
    Under Configuration, the following fields are available:
    •  Interface Enabled:
    Indicates whether the wireless interface is enabled or disabled.
I have a Speedtouch 780, the manual for that says exactly the same and I am able to switch off the wireless network on that.  It is just a case of ticking or unticking a box to enable or disable the wireless network and this can be done on the following configuration page: Home > Home Network > Interfaces > WLAN: SpeedTouch123456
PhyllisTyne
Thanks but I want to be able to turn it on and off with a hardware switch.
PT
Fixes: 167
After a few attempts it does appear to turn the wireless off, you have to hold it for around 15 seconds tho.
 Chris Parr
 Plusnet Staff
PhyllisTyne
Quote from: PJ
Switch the router itself off? Using the mains if necessary.
don't want to lose ADSL/LAN thanks!
PT
PhyllisTyne
Quote from: Chris
Cheers Chris,
and it doesn't come back on again untill you hold it in for several seconds again?
PT
Fixes: 167
Yup, hold it down for a similar amount of time to turn it back on.
 Chris Parr
 Plusnet Staff
PhyllisTyne
Thanks again chris
PT
PhyllisTyne
picked up a new one off fleabay for £25 delivered. didn't think I could go wrong!
PT
