Speed test - help needed
- Speed test - help needed
23-12-2011 11:49 AM
Hello.
I am now running Windows 7 64-bit, and I am unable to run the speed tester, I think it might be windows firewall blocking the test.
Any ideas as how to fix this please?
Many thanks.
jim:red all caps removed from title as per Forum Rule mod:end
Many thanks.
6 REPLIES 6
Re: SPEED TEST, HELP NEEDED
23-12-2011 11:52 AM
Which speed tester? (If it's the BT one make sure you've got Java installed as it won't run without it.)
Re: Speed test - help needed
23-12-2011 12:04 PM
Hello.
I should have said it's the Plusnet speedtest.
23-12-2011 12:04 PM
Moved to Windows Forum as it sounds like a Windows specific problem
Which browser are you using
23-12-2011 12:14 PM
Hello again.
Internet explorer 9
Internet explorer 9
23-12-2011 12:33 PM
Just tried using IE9 on Win7 64 bit with cookies blocked - just in case - and no problem
What is the exact error message and is this the link you are using http://www.mybroadbandspeed.co.uk/
23-12-2011 12:40 PM
Hi.
No error message, when i click on the speedtest start button, no response at all.
Just fixed it! It needs Java installed to run.
Many thank's
Many thank's
