Speed checks sites still unreliable
- Speed checks sites still unreliable
11-03-2009 11:24 PM
2 REPLIES 2
Re: Speed checks sites still unreliable
12-03-2009 7:46 AM
Did you see the comments at the bottom of the "Exclusive" Telegraph report dated 11 Mar 09. Lots of other reports of the "news" dated last October 08, Nearly as slow as the speedtests
12-03-2009 7:51 AM
I think speedtests are purely a guide. It's best to use one and stick with it so at least you can compare your results from test to test. It's not always good to compare between different test sites.
