Speakers crackle, hardware of software issue
- Re: Speakers crackle, hardware of software issue
24-04-2008 7:57 PM
24-04-2008 8:23 PM
24-04-2008 8:50 PM
Here is the screengrap, of the audio devices, only thing that can be uninstalled is the AC97 audio.
24-04-2008 8:54 PM
24-04-2008 8:59 PM
24-04-2008 9:06 PM
24-04-2008 9:07 PM
Sorry...just read your full original post
24-04-2008 9:10 PM
but I have plugged in a set on headphones, and all was well.
I think he tried that, Strat !
24-04-2008 9:12 PM
24-04-2008 9:12 PM
@shutter, Dont think I was too harsh. This has happened, after the 2nd reinstall, after a disaster with the mini PCI wireless card, that stuffed up the network settings so much, and as I had nothing else on the system, I redid the install again, so this problem is after the 1st install after the rebuild. After 1st Install, untill the WIFI card issue, all was well. ( does that make any sense at all :o). May strip the thing down again and take a good look at the speakers. If they seem Ok, not sure what to do
24-04-2008 9:12 PM
24-04-2008 9:18 PM
24-04-2008 9:21 PM
Usually there is no electronics between the headphone socket and the speaker terminals to cause a problem so a strip down seems likely.
24-04-2008 9:22 PM
24-04-2008 9:29 PM
