Sound effects
Fixes: 8
Sound effects
Does anyone know if it is possible to get some free sound effects for windows XP ?
The existing one is driving me nuts it sounds like an ice cream van.
Also is it easy to change the sound effects ?
Fixes: 49
Re: Sound effects
Depends what you are after. There is a selection here but you can Google loads more.
It's fairly simple to change default windows sounds.
Customer and Forum Moderator.
Denzil
Re: Sound effects
Some instructions <a href="http://www.microsoft.com/windowsxp/using/setup/personalize/sounds.mspx">here</a> on how to change them.
