Sound Problem
FIXED- Subscribe to RSS Feed
- Re: Sound Problem
18-03-2021 9:30 PM
Machine :- ACER ASPIRE SWITCH 10
Operating system(s) ...... LInux Mint 19.3 or PCLinuxOS
Both are "new" installs, and only single installation.. i.e. not dual boot.
Problem is NO SOUND when trying to play music videos with VLC or SMPLAYER
Initially, I thought it may have been a faulty download of Linux MINT 19.3 however a new download and install gave the same NO SOUND result... so I tried PCLinuxOS as an alternative but again.. NO SOUND..
During my investigations to try to rectify this.... Phones plugged in... Volume control at maximum ( not muted)
checking on "Sound Preferences" at one stage, I saw a message saying that "PulseAudio" was DISABLED, but cannot find a way to ENABLE it.
other avenues reveal the contents on the following pics
On a "first run" with VLC ... this message appeared...
Which started the quest....
The above are photo`s of LINUX MINT Sound Preferences....
Below photo`s are of the PCLinuxOS Sound Preferences
Note the word "Disabled" and "Off" no way to change that..( usually right click produces something.. but no response on that action)
Note the Dummy Output notice.......
Checking the Synaptic Package Manager via "search" for Pulse Audio... gave this result....
Showing that it IS installed...
Any suggestions or instructions..... gratefully received.....
Thank you for looking ......
Fixed! Go to the fix.
Re: Sound Problem
19-03-2021 7:27 AM
videolan@videolan.org
Re: Sound Problem
19-03-2021 8:44 AM
@Gel Thanks for the suggestion... but vlc works fine on my other laptop .... also... the "NO SOUND" is applicable to another media player.. ( SMPLAYER ) .. and another program that I use, also has no sound. (not a media player program)
The problem seems to me, to be the fact that , although PulseAudio is installed, for some reason on the ACER ASPIRE laptop, it is disabled.... and I do not know how to Enable it again.
Re: Sound Problem
19-03-2021 8:58 AM - edited 19-03-2021 9:00 AM
@shutter does sound work at all ?
does the Sound settings utility show any real sound devices ? It doesn't look like it from your screenshots
Sounds(sic) like Linux hasn't detected any compatible sound devices on that laptop
Re: Sound Problem
19-03-2021 9:05 AM - edited 19-03-2021 9:14 AM
@shutter a quick google seems to confirm a similar problem
Have a look at this https://forums.linuxmint.com/viewtopic.php?t=274487 and particularly the link to https://github.com/heikomat/linux/tree/cx2072x/cx2072x_fixes_and_manual
edit: from that 2nd link it looks like you need a kernel > 5.3 to support the sound card. I (think) Mint 19.3 is 5.0?
That 2nd link appears to be a kernel patch so future kernel updates might be a problem...
might be worth trying Mint 20.1 first as that comes with kernel 5.4
Re: Sound Problem
19-03-2021 9:57 AM
Hmm... no.. I have a morse program, that I use on 19.3 on another laptop... and also the SMPLAYER is my normal media player. and they both work with no problem.
so I`m not sure about 19.3 being the problem here... especially as I also installed ( fresh new install) PCLinuxOS on the ACER
On the Sound Preferences on my ASUS it shows "Built in Audio-Analogue Stereo" for the sound app... which is "Normal" for Linux Mint I think... and Linux uses Pulse Audio as the sound card driver
I have noticed that when a video is playing on screen, and one of the pages of the sound settings is showing a bar across the screen... jumping about long and short, as if driven by the sound of the music... ( as expected) so it looks as if "part" of the system is working... just not getting OUT of the sound card to the speakers/phones
Re: Sound Problem
19-03-2021 9:59 AM
Thanks for the linkys ... I`ll go and have a look and see if they are applicable... Mint 20 is an option... which I `ll download while messing about ! .
will report back later.
Re: Sound Problem
19-03-2021 2:04 PM
@MisterW Well, I have done what it said on the linky... and no change.... still no sound... and the "preferences" still show that same long message about hdmi video..
even tried the " if the above does not work ... try this "...
so.. now I am going to install Mint 20.1 and see if that makes a difference.
catch up later....
19-03-2021 3:45 PM
Re: Sound Problem
19-03-2021 4:06 PM
Re: Sound Problem
19-03-2021 4:38 PM
Re: Sound Problem
19-03-2021 5:27 PM
I'm just pleased I was right. I don't need the fix credit
