Sounbars for improving TV sound.
- Sounbars for improving TV sound.
25-01-2015 1:52 PM
Re: Sounbars for improving TV sound.
25-01-2015 1:59 PM
28-01-2015 5:35 PM
I am sure that there could be a sensible Bar at a reasonable cost/spec about somewhere, it is just finding a maker to look at their publicity documents that bugs me. We are singularly short of the sort of dealer to chat to hereabouts.
28-01-2015 6:04 PM
Both my parents now use them on the television and they can individually control their own volume. Cutting out the background noise and echoes also massively improves the ability to hear what is going on and you can therefore reduce the volume level accordingly anyway.
My father in law has also now adopted this approach and loves his new cordless headphones (he was recommended to try them by my parents). His wife also loves the fact she doesn't have to have the television blaring constantly
28-01-2015 6:44 PM
besides your swmbo will probably like the extra space
29-01-2015 12:53 PM
Ta!.
29-01-2015 2:40 PM
These work well, as would any cheap speakers which are advertised as being for connecting to a PC, this may give you many further size and style options instead of just looking at soundbars, which may or may not fit the TV cabinet you already have.
I do not consider the Bose products are worth the price.
3Mb FTTC
29-01-2015 4:19 PM
Quote from: colintivy I am at an age that many broadcast dialogues seem to be muffled.
I had that problem early last year, I found a pair of NHS hearing aids worked wonders.
03-02-2015 3:51 PM
Cordless Headphones sound like to be the easiest option. I assume that all they need is the headphone output from the TV and a mains supply which can be switched as required. I fancy one of the plug/sockets controlled by a mini remote control, I have a variety of these for controlling lights and even my computer accessories to save grovelling down to reach the wall sockets. What varity of phones did your elders prefer?
@ sjptd.
I do have a pair of reasonable Tannoy speakers on steel mounting columns spare which were for my HFIish system before I inherited my Kefs. They are about half the size of the massive KEFs and might just be tolerable to SMBNO. Do you know of any modest modern amplifiers which could accept the phone input and could be housed in the back of the TV cabinet, which is very deep being originally designed to accommodate a large CRT set?
@ godsell4.
You see where I might be going from the above. Your advice re Bose is well taken, I have always been suspicious of their attitude and thier very active publicity machine!
03-02-2015 4:39 PM
http://www.amazon.co.uk/TA2020-Tripath-Class-T-Amplifier-Supply-Black/dp/B007VMA6OU/ref=cm_cr_pr_pro...
http://www.amazon.co.uk/TA2024A-Tripath-Class-T-Amplifier-High-Fidelity-Black/dp/B00LHB3KYE/ref=sr_1...
There are slight variations between the 2020/2020+/2020A and 2020A+. Not sure what they are or how much they matter.
My son has these for TV output (and also sometimes computer output) with decent B&W bookshelf speakers and is quite pleased with them; and he is fairly demanding.
(If you have old KEFs and Tannoys you may also remember hearing about the Sinclair PWM amplifiers. These work on the same principal; with the difference that these do work and work well, whereas by all accounts the Sinclair's usually didn't work, and when they did work sounded terrible.)
03-02-2015 8:45 PM
You pop them on their stand / base station and they will recharge when not in use. They also have an auto on / off depending on whether the telly is on and the headphones off the stand.
03-02-2015 8:48 PM
www.amazon.co.uk/Sennheiser-Wireless-On-Ear-Headphone-Ireland-Black/dp/B005SO0OFE/ref=sr_1_7?ie=UTF8...
There are some Thomson ones which have had good reviews for half the price but I've not had any experience of those.
08-02-2015 8:43 AM
We have this one
http://www.tesco.com/direct/panasonic-sc-htb8-80w-soundbar-with-bluetooth/687-9932.prd?pageLevel=&sk...
The sound is fantastic, it's low profile, and you can have it flat on your tv stand or wall mounted (to change the direction of the soundwaves, it's switchable electronically. Makes a great difference).
There's only two controls (on a remote) to worry about. Clear voice (which brings voice to the front. Very handy when watching something with background music. Saves constant rewinding and turning up the volume. We don't keep saying "what did he say?" now.
There's also surround sound -self explanatory-works well.
Bluetooth too, great for listening to music from your phone, tablet or laptop.
We wish we'd bought one years ago.
