Sonos play with Alexa
- Sonos play with Alexa
23-05-2020 11:18 AM
Re: Sonos play with Alexa
23-05-2020 11:23 AM
This topic has been moved from ADSL Broadband to Tech Help.
23-05-2020 12:07 PM - edited 23-05-2020 12:07 PM
@Paul57 I'd start by trying with your old BT hub. Theres plenty of information on here how to use it with Plusnet , start with this https://community.plus.net/t5/My-Router/BT-Home-Hub-6-Smart-Hub-on-PlusNet/td-p/1349153
23-05-2020 3:44 PM
23-05-2020 3:47 PM
23-05-2020 5:24 PM
@Paul57 the BT Home Hub 5 WILL work with PlusNet. You just need to follow the guide, its basically the same for HH5 and smart hub
23-05-2020 5:28 PM
23-05-2020 5:48 PM
As long as you still have the information card with the default admin password, then factory reset it with the reset button and you should then be able to get in
23-05-2020 7:05 PM
My Sonos play one with Alexa works as it should except it will not play music when requested
23-05-2020 7:24 PM
In the first post you said it all worked fine when using the Bt hub on a bt connection, is that correct ?
In which case using exactly the same hardware setup should work on plusnet once the bt hub is reconfigured with your plusnet username and password
