Something has stolen 11GB from my disc space - Sorted - it was system restore
Oldjim
Fixes: 63
I just spotted the disk space warning on my C partition which said I had only 8.35GB free of 97.6GB so decided to investigate
Operating system Win 7 64 bit
These are the results - with hidden and system files set to show
windows 	42.5
programs 3.37
programs (x86) 2.43
nvidia         1.75
garmin         0.74
users         9.34
page file 0.2
hyberfil.sys 6.25
prog data 4.48
recycle      6.8
Total       77.86
To add the System Information Volume shows as empty and that was where I would have expected the restore files would be
2 REPLIES 2
jelv
Fixes: 10
Re: Something has stolen 11GB from my disc space - Sorted - it was system restore
https://windirstat.info/index.html may help you find exactly what is taking the space.
If windows\winsxs is huge have a read of https://support.microsoft.com/en-us/kb/2795190 (Google will find you loads of other information)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Fixes: 63
crikey 25GB - will have a read
Ran System Cleanup didn't seem to make much difference although it took a long time doing it
Another check - that folder size hasn't changed
Didn't realise I needed to do a reboot  Embarrassed
After a very very long restart  I now have nearly 28GB free and winsxs is down to 15GB and Windows only 31GB
