Software running in the background
- Software running in the background
12-05-2015 10:04 PM
Any suggestions what I should be looking for, and where/how to find it?
I have Zone Alarm, Malwarebytes, Microsoft Security Essentials.
My thanks for any help
Re: Software running in the background
12-05-2015 10:48 PM
firstly Run MSCONFIG from windows search , under services make sure you tick hide MS services and check if something looks odd . also look at start up
or you can try " https://technet.microsoft.com/en-gb/sysinternals/bb963902.aspx " which will show what is running or auto starts
13-05-2015 12:39 AM
13-05-2015 1:08 PM
I didn't pursue it as I'm happy for the likes of Kaspersky to start early in the boot process.
I have a feeling it was generated by Event Viewer but can't replicate it.
13-05-2015 1:58 PM
Easiest way to find out is with taskmgr, in performance click the resource monitor and look at what is using your hard drive, it will me MSMPeng.exe that is crunching on it the most
13-05-2015 8:55 PM
I'll let you know how things stand after a couple of days
Thanks for all the suggestions
13-05-2015 9:19 PM
14-05-2015 9:29 AM
14-05-2015 12:32 PM
http://community.plus.net/forum/index.php/topic,137931.msg1212543.html#msg1212543
Using Resource Monitor also helped me to spot 'WildTangent' thrashing away the HDD at the same time as Windows Updater and its associated processes - don't know exactly what it was doing or how often it does it but I removed the program (which came pre-installed on my HP PC) anyway as I never use it.
16-05-2015 7:02 AM
I have used taskmgr to try to spot what is busy, but nothing stands out. However, I don't really understand what taskmgr resource monitor is telling me. What should I be looking for? I have looked at the disk activity, and the processes and their various data figures are changing all the time. Some processes seem to be listed more than once. Some processes seem to come and go. Do I look for the bigger PID figures, or what? Taskmgr Resource Monitor did show that my memory is being heavily used, so I am getting some more - that will take about a week to arrive.
I am going to run CCleaner, but I don't have a lot of confidence that will solve the problem.
Onwards and upwards
16-05-2015 9:11 AM
CCleaner is a good place to start, but don't let it remove your cookies unless you want to do a lot of re-entering of personal details for your favourite websites.
Malwarebytes is a reliable program for ensuring you have removed malware, although you are apparently using that anyway.
'UltraDefrag' is a useful free utility for defragging your disk, and can be set to run from the boot sector, which saves a LOT of time.
Make sure your power management is set to 'recommended settings' (although you can tweak the screen and disk time-outs.)
Also check that your system memory settings have not been changed to favour appearance over performance.
I use the 'Overview' tab of Resource Monitor, and expand the CPU. DISK and MEMORY tables so I can see what's happening with all 3 at the same time.
If you click on column headers 'CPU', 'Total (B/s)' and 'Commit (KB)' respectively the processes and their usage will automatically sort in descending order, which makes it a lot easier to spot which are using the most resources even though they are constantly changing..
You can expect to see a lot of 'pagefile.sys' activity on the HDD, and if you have Windows Updater set to automatic you will see 'datastore.edb' madly reading and writing to the disk soon after boot up.
If you can see evidence of your antivirus programs taking up lots of resources it could be they are set to scan more frequently than is really necessary.
As in my previous post, look for programs running which you don't actually use but which are using resources.
Installing more RAM should help - Resource Monitor will no doubt give you a clue as to how much, and whether the swapping activity of the HDD also decreases.as a result.
16-05-2015 12:28 PM
I can see what activities are the busiest, but I am unable to identify what activities can be stopped. How I stop them is the next question. Any suggestions?
16-05-2015 12:33 PM
16-05-2015 1:12 PM
I only run MSE or Spybot 1.6.2 as and when I remember to - usually weekly or so. Does either have a facility for running continuously? If so, how do I stop them?
16-05-2015 1:20 PM
