So you want the latest CPU but don't want Windows 10
- Re: So you want the latest CPU but don't want Wind...
22-04-2017 12:12 PM
This is how to enable updates with older Win systems
Re: So you want the latest CPU but don't want Windows 10
22-04-2017 2:04 PM
The 'solution' appears to require you to tamper with a Windows system file. I would hope that my security software would pick this up and take action, although presumably one could instruct the security software to ignore this particular file.
22-04-2017 2:41 PM
No need to tamper - just load Linux.
22-04-2017 2:49 PM
I did think of adding - Keep your nose out VileReynard but knew it would be just a waste of time as you would just troll as usual
22-04-2017 3:03 PM
I provided a valid solution - call it trolling if it suits you, I don't care.
23-04-2017 10:19 AM
using linux is NOT a valid solution to getting windows updates.
