Smashed my system again
- Smashed my system again
14-03-2016 7:56 PM
Quote neil@neil-Excel:~$ sudo apt-get autoremove
[sudo] password for neil:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages will be REMOVED
linux-image-3.13.0-83-generic linux-image-extra-3.13.0-83-generic
0 to upgrade, 0 to newly install, 2 to remove and 0 not to upgrade.
2 not fully installed or removed.
After this operation, 147 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 325530 files and directories currently installed.)
Removing linux-image-extra-3.13.0-83-generic (3.13.0-83.127) ...
depmod: FATAL: could not load /boot/System.map-3.13.0-83-generic: No such file or directory
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-83-generic /boot/vmlinuz-3.13.0-83-generic
run-parts: executing /etc/kernel/postinst.d/dkms 3.13.0-83-generic /boot/vmlinuz-3.13.0-83-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-83-generic /boot/vmlinuz-3.13.0-83-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-83-generic
grep: /boot/config-3.13.0-83-generic: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_2OYGV7/lib/modules/3.13.0-83-generic/modules.order: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_2OYGV7/lib/modules/3.13.0-83-generic/modules.builtin: No such file or directory
run-parts: executing /etc/kernel/postinst.d/pm-utils 3.13.0-83-generic /boot/vmlinuz-3.13.0-83-generic
run-parts: executing /etc/kernel/postinst.d/update-notifier 3.13.0-83-generic /boot/vmlinuz-3.13.0-83-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.13.0-83-generic /boot/vmlinuz-3.13.0-83-generic
Generating grub configuration file ...
Warning: Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.
Found linux image: /boot/vmlinuz-3.13.0-79-generic
Found initrd image: /boot/initrd.img-3.13.0-79-generic
Found linux image: /boot/vmlinuz-3.13.0-77-generic
Found initrd image: /boot/initrd.img-3.13.0-77-generic
Found linux image: /boot/vmlinuz-3.13.0-76-generic
Found initrd image: /boot/initrd.img-3.13.0-76-generic
Found linux image: /boot/vmlinuz-3.13.0-74-generic
Found initrd image: /boot/initrd.img-3.13.0-74-generic
Found memtest86+ image: /boot/memtest86+.elf
Found memtest86+ image: /boot/memtest86+.bin
done
Removing linux-image-3.13.0-83-generic (3.13.0-83.127) ...
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.13.0-83-generic /boot/vmlinuz-3.13.0-83-generic
update-initramfs: Deleting /boot/initrd.img-3.13.0-83-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.13.0-83-generic /boot/vmlinuz-3.13.0-83-generic
done
The link /vmlinuz is a damaged link
Removing symbolic link vmlinuz
you may need to re-run your boot loader[grub]
The link /initrd.img is a damaged link
Removing symbolic link initrd.img
neil@neil-Excel:~$
Computer froze while updating and had a broken kernel. Managed to chroot with a live CD and boot into the previous kernel and this is the error I get. Daren’t reboot right now with it mentioning grub in case I can't back into a working system.
Re: Smashed my system again
14-03-2016 8:33 PM
14-03-2016 9:26 PM
In fact, why did you run auto-remove at all?
Personally, if I'd seen that, I would check & possibly manually remove a couple of older kernels!
In future, if you run autoremove, then I would answer N to the proceed question and run
sudo apt-get purge list-of-packages,
where you only remove packages that look safe to remove.
The line that said
should have been an extra alert.
Quote 2 not fully installed or removed.
Why not try reinstalling grub as it suggests?
(Actually sudo update-grub, followed by a reboot) might be sufficient
This should recreate the links to boot from your existing kernels.
If it doesn't work, you could still use your present method to boot the machine.
14-03-2016 9:58 PM
I was hoping now the offending kernel was removed I could simply go back through the update process and get back to the latest but no update is available. Didn't want to delete any earlier kernels in case I couldn't get back to a working machine. I'm sure I've been here before as well
14-03-2016 10:34 PM
The new kernel should be sitting in the repositories.
You could try running a copy of your OS in a VM & try to break it...
14-03-2016 10:41 PM
Quote So its working now?
Yeah back working. So it's ok to download again from say synaptic even though its not showing in any updates? I read somewhere before that doing it that way manually rather than the update process can lock you at that version.
Quote You could try running a copy of your OS in a VM & try to break it...
15-03-2016 10:22 AM
uname -r
3.13.0-79-generic
neil@neil-Excel:~$ sudo update-grub
done
neil@neil-Excel:~$ sudo apt-get upgrade
Calculating upgrade... Done
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
83 not showing as an option to upgrade or in the grub list.
In Synaptic showing has installed, tried mark for re-installation which it goes through the procedure. Reboot and still on 79. Do you think I should mark it for complete removal then check for updates again?
15-03-2016 10:53 AM
sudo apt-get install linux-generic
did the trick. Can't believe I managed to rescue this system from a freeze during kernel installation. There's hope for me yet
15-03-2016 1:15 PM
Haven't a clue about pinning...
But I've never pinned a package in my life - I once messed up a kernel trying to install some video drivers,
so I just ran on a slightly older kernel for a few months.
Eventually, a new kernel came along & it installed perfectly.
15-03-2016 2:10 PM
Quote Regarding your comment about pinning your kernel?
15-03-2016 3:34 PM
Quote from: AverageWhiteBloke Not sure what you mean, did I mention pinning?
When I saw that I looked and couldn't find where you had mentioned pinning !
I can only assume pinning refers to the ability to force Linux packages to be a particular version, and therefore prevent updates from changing them.
I have used that functionality in the past, when the old BBC iPlayer needed a specific out-of-date version of Adobe-Air, so I used "synaptic" to force a particular version so I didn't accidentally break it when running updates.
15-03-2016 9:52 PM
Quote I read somewhere before that doing it that way manually rather than the update process can lock you at that version.
I read somewhere when looking for answers to this problem that if you load a kernel from anywhere other the updates it will lock you at that kernel. I think it was more to do with unreleased kernels though which I guess you would have to force the installation and possibly locking it.
All good though things are working again regardless.
15-03-2016 9:54 PM
