Smartdefrag installer with Extras if not careful
- Smartdefrag installer with Extras if not careful
07-07-2014 12:44 PM
Just updated smartdefrag today to 3.2 and its installer is really starting to get annoying with all the crap it wants to install. So just a heads up as ever with installers, never choose express install always custom, they hide extra browser tools/forced search engine changes if not.
FTTP 500 regrade from Tues 28th November
5 REPLIES 5
Re: Smartdefrag installer with Extras if not careful
07-07-2014 12:47 PM
Cheers for the heads up Gus
07-07-2014 12:54 PM
if running win 7 / 8 do you still need a defrag tool?
07-07-2014 1:00 PM
Considering M/S has their own version built in to both 7 / 8 then I would say yes
Unless you have a SSD as you will degrade the life of the SSD by defraging it
07-07-2014 3:01 PM
@dvorak if the windows defrag was any good I wouldn't, I used to use diskeeper until they started forced new build versions at a price and settled on smartdefrag which works better than the windows tool. Just that Iobit have an annoying installer with hidden rubbish since version 2.3ish
07-07-2014 5:50 PM
Unchecky will help
http://unchecky.com/
