Smart plug
- Smart plug
Smart plug
a month ago
I have a couple of smart plugs and for the life of me can't get them connected up.
They connect on another WiFi elsewhere at another house, different router.....but not my plusnet router
3 REPLIES 3
Re: Smart plug
a month ago
Are the two mains sockets on the same ring main, and are you using an extension lead?
The older I get, the earlier it gets late.
ADSL2+ Billion 8800NL
Re: Smart plug
a month ago
Try factory reserting them and set them up from scratch.
Re: Smart plug
a month ago
That was it..... extension lead.... thank you.
